2003 Audi A4 RUNNING POOR
2003 AUDI A4
95 MILES • 4 CYL • FWD • MANUAL
CATA4
Hi between 1500rpm and 2000rpm the car seems to hesitate slightly any other rpm the car is ok
Jul 3, 2010 at 7:35 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 3, 2010 at 1:34 PM
MADMIKE1735
  • 951 POSTS
hopefully there is a check engine light on... if so, it will most likely be a certain cylinder misfire.... for example, if u get a code which is a cyl 3 misfire, then u narrow it down to either a coilpack, or a plug... at 95,000 miles, id put plugs in it.... either NGK, or denso, either way, they have to be platinum for that car.
Aug 26, 2010 at 2:48 PM
