2003 Audi A4 Losing power in second gear
BOOMERLOO
Transmission problem
2003 Audi A4 Manual 91000 miles
I have started to experience loss of power when in second gear. Basically, once it hits 2000 revs the cra slows. If I drop it into neutral and then back into second it speeds up or if i move to third all seems ok. Any ideas what could be causing this?
Aug 10, 2008 at 11:46 PM
KHLOW2008
  • 41,812 POSTS
Hi boomerloo,
Is the CEL showing?
Did you check the spark plugs?
Is there any misfiring when rpm reaches 2,000?
Aug 11, 2008 at 2:19 AM
BOOMERLOO
Nothing showing on the CEL so far and no misfiring either.
New spark plugs only a couple of months back too.
Aug 12, 2008 at 12:22 AM
KHLOW2008
  • 41,812 POSTS
Hi boomerloo,
Does engine lose power at 2000 rpm in 1st, 3rd or 4th?
I would suggest checking the EGR and fuel filter.
Aug 12, 2008 at 1:37 AM
