2003 Audi A4 HELP PLEASE ? RE: ENGINE & REPAIR
92,000 MILES • 6 CYL • AWD • AUTOMATIC
AMES5330
i have a 2003 Audi A4 Quattro, w 92,000 miles. I took it to get looked at when one of my oil lights went on. This is what I was told..."...misfires stored on multiple cylinders w boroscopy, found when engine is off coollant is entering cylinders. suspect engine short block or cylnder head gaskets will need to be replaced, need more diagnostic time..."
The car sends a small puff of smoke when started only. I am really in need of help here
May 2, 2010 at 6:00 AM
MATHIASO
  • 1,209 POSTS
Hello ames5330
borescope reduce diagnostic time compare to old fashion way of performing a vacuum test to prove that the cylinder is leaking due to head gasket. it is primary use in aircraft maintenance because it magnify discontinuities that cannot be detected by the naked eye and ii) to permit visual checks of critical areas not accessible to unaided eye and difficult for other nondestructive tests.
When you took your Audi to check for the oil light. There was no engine light and that is what surprised you about the misfire code.
Before engine light is shown on the dash, computer store some code(s) in pending zone, that mean it 's counting until it happens a certain number of times before releasing the light on the dash. Most new scan tools can read both trouble codes "code that causes trouble right now " and pending codes" code that are pending but are not trouble yet to illuminate engine light.” when they become trouble, the check engine light comes on.
I believe your mechanic have found the misfire code in "pending” leading to the use of borescope.
What he should do is to fix the oil light and advice you that your engine may be in trouble in the future because there might be a head gasket problem.
The decision should be up to you to take the car to another mechanic if you suspect your engine is misfiring and you get engine light.
it is unprofessional to drag you into cost of repair for which you did not bring the car for. You should get a second mechanic opinion so you can decide what you want to do....
May 2, 2010 at 4:53 PM
