2003 Audi A4 Gearbox replace
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
GEORGE METAXAS
Dear Sirs,
I have to replace my Audi A4 1.8 turbo tiptronic gearbox. The transmission code is GEB x x x. I found recon gearbox but the transmission codes are: EVE, DXE, DMX. I am wondering if is ok to replace it with one of the above or if you recoment me any other transmission code.
I am looking hearing from you soon.
Thanks,
George
updated 3/6/09
DEAR SIRS,
THE VIN NUMBER OF THE VEHICLE IS WAUZZZ8E73A271716 THE SIZE OF THE ENGINE IS
1.8 TURBO VERSION FAVJG0R8E60O, ENGINE NUMBER IS BFB 017053.
BEST REGARDS,
GEORGE
Mar 4, 2009 at 2:02 AM
JAMES W.
  • 2,394 POSTS
George, I need to know the VIN # of your vehicle and the engine code or size. Please advise.
Mar 4, 2009 at 10:26 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated You will have to replace the transmission with a trans of the same GEB code for the gear ratios to be the same for your engine.. it's a multitronic 01JH cvt (continuosly variable transmission) Hope this helps .. let me know
https://images.2carpros.com/forum/automotive_pictures/266999_audi_3.jpg
Mar 4, 2009 at 10:42 AM
DAVE H
  • 13,383 POSTS
Dear Dave, You thing that GEC model might be ok for my car? Thanks. George Metaxas Hey George. You need to replace the transmission with the GEB code letter trans...it has to be an 01J H trans ...for the gearing ratio's to be the same or it will not function correctly !!
https://images.2carpros.com/forum/automotive_pictures/266999_audi2_1.jpg
Mar 4, 2009 at 10:51 PM
DAVE H
  • 13,383 POSTS
Dear Dave,
So as I understand we have no option than the specific gearbox. Do you have
any idea where to look for the specific model.
Thank,
George
Hello George.
I'm afraid you will need the same gearbox !! the ratio's are specific to the tiptronic 1.8L engine and ECU .. as I don't know where you are located (country) I cannot supply a recon gearbox distributor ... have you tried EBAY ? .. let me know
Mar 5, 2009 at 12:50 AM
