2003 Audi A4 Automatic gearbox problem
GEORGE METAXAS
Transmission problem
2003 Audi A4 4 cyl Two Wheel Drive Automatic
My name is George Metaxas from Cyprus. Few days ago i asked you some question regarding my car's automatic transmission. I tried to replace it with a used one but unfortunately i cannot find one. I am wondering if is possible to replace the automatic one with manual transmission and what parts i will need to do the whole subject. What do you thing about that and what kind of manual gearbox is ok for my car:
Audi A4 1800cc Turbo
Automatic CVT tip (transm. code: GEB xxx)
Year of manufacture 2002 registered 2003
Chassis No: WAUZZZ8E73A271716
Engine No: BFB 017053
Mar 13, 2009 at 8:05 PM
2CARPRO JACK
  • 11,533 POSTS
That would probably be more expensive than having your automatic rebuilt.You would have to change the wiring harness, trans,flywheel,clutch, pedal assembly under the dash, install a clutch master, possibly different crossmember, possible driveshaft length differences, shifter, possible center console/parts
Mar 14, 2009 at 1:23 AM
