2003 Audi A4
KEETU
  • 2003 AUDI A4
  • 6 CYL
  • AWD
  • 62,000 MILES
Hi. My car makes a really loud noise when I turn the steering wheel. At first, I thought I was low on power steering fluid but that was not the case. The car makes the same noise when in the park position, the ignition is on and I press on the accelerator. This has happened twice when it's cold outside. I drove it when it was making this noise and something started to smoke under the hood. I checked power steering and coolant fluids and both tanks had adequate amounts. The temperature guage stayed between Cool and Hot. There are not leaks either. What could be the problem. Thank you so much.
Monday, February 11th, 2008 AT 4:42 PM
KEETU
The response to this post is that the power steering rack was cracked. The whole thing had to be replaced and cost $1500 for the part and labor.
Saturday, February 16th, 2008 AT 9:00 PM
CPCBR600
Its the ball bearings. That happend to me and I got them replaced now is quiet again.
Wednesday, February 20th, 2008 AT 3:27 PM
