2002 Audi A4 Oil question
2002 AUDI A4
80,000 MILES • 4 CYL • 4WD • MANUAL
SUTTONBEN1988
Hi ive recently bought the above car and the place I bought it from has said that the vehicle has had a full service but iam having my doubts.
The main reason for doubting it is the fact the vehicle had basically no oil in it atall. So I phoned them up and they said it aparently takes a while for the oil to get into the filters and it always needs filling up after a service.
Is this true.
And is there anyway I can pysically check if the car has had a service or not?
Kind regards
Ben
Mar 29, 2010 at 10:25 AM
RENDERFULLER
  • 7 POSTS
Yes it is true it does need to be checked and added to after a service because when you change the oil filter most people just put it on empty then the car fills it up upon start so you will be down about a half quart to as much as 1 quart, However it will still register on the dip stick even after the change it will just be toward the low line on the stick. Some places dont even check the level when they change the oil they just look up what the computer tells them it will hold and fill it to there and call it good. as an example I own a Lexus S.U.V. that calls for 5.5 quarts from the factory, It actually takes 7.0 quarts to get it full. So when my Quick change place pumps in 5.5 quarts and the filter holds 1 quart i am only half full of oil and it barely registers on the stick. The only way to check the service is by the color of the oil. Audis tend to darken oil fast so if it is clean then it probably was done recently. Good Luck.
Aug 2, 2010 at 6:51 PM
