2002 Audi A4 Hard to start
78,000 MILES • 4 CYL • AWD • AUTOMATIC
IOWAAUDI
After I park my car for a long time, mainly at work for 8 or 9 hours in the hot sun, it is somewhat hard to start. It may take 2-3 seconds of cranking to start but right when it does start it is perfectly fine. and if i shut it off right after i get it started, it turns over immediately when re-started. It is turbocharged and i always allow it to cool down properly after driving so i dont think that can have anything to do with it. Why is this? and what can be checked or fixed?
Jun 30, 2008 at 8:56 AM
LEGITIMATE007
  • 5,121 POSTS
I would check the mass airflow sensor first.
Jun 30, 2008 at 9:13 AM
IOWAAUDI
what exactly should i check for?
Jun 30, 2008 at 3:05 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Just see if it impacts the car whether it is connected and then disconnect. You could try to use a shop vac and measure resistance values but I don't know of a table to compare it to. Have you checked the usual tune up routine lately (plugs, wires, air filter,fuel filter, etc.)
Jun 30, 2008 at 3:34 PM
LEGITIMATE007
  • 5,121 POSTS
thanx airsoft
Jun 30, 2008 at 11:52 PM
