2002 Audi A4 engine knocking
130,000 MILES • 4 CYL • FWD • MANUAL
FRANKDOMINGUEZ
the car has loss of power and the engine is knocking
Dec 4, 2009 at 1:46 PM
  • 31,937 POSTS
HI there,
This does sound ominous, i would start with a comp test, and check the oil pressure with a mechanical gauge, if the knock is a deep hollow knock constant with engine speed, this well may be a failed main bearing, you will need a mechanic to listen to this to confirm the diagnosis.
Mark (mhpautos)
Dec 4, 2009 at 1:50 PM
