I have a P0411 engine code secondary air, what is the most common area to focus on.
Mar 17, 2008 at 1:40 PM
2CARPRO JACK
✓Experienced Mechanic
I would look at the check valves where the AIR pump hoses hook up at the exhaust manifolds. The can break internally causing exhaust to go up into the AIR pump.
