2002 Audi A4 check engine light
62,000 MILES • 4 CYL • 4WD • AUTOMATIC
RWAGONER
I have a P0411 engine code secondary air, what is the most common area to focus on.
Mar 17, 2008 at 1:40 PM
2CARPRO JACK
  • 11,533 POSTS
I would look at the check valves where the AIR pump hoses hook up at the exhaust manifolds. The can break internally causing exhaust to go up into the AIR pump.
Mar 19, 2008 at 1:09 AM
