Engine Performance problem
2002 Audi A4 4 cyl All Wheel Drive Manual 125k miles
hello i have a audi a4 2002 1.8t, when it is cold outside around o degrees F or colder at exatcly 1100 rpm the car studders and is not smooth, above or below 1100 it is fine and only in very cold weather fortunately going maybe 5 minutes the problem is completely gone and fine, even if i stop for 2 hours and start the car again it is fine. I removed the maf sensor and cleaned it carefully not touching anything, I used electrical contact cleaner, did not help. I have vag com and have no codes. maybe i need a new maf sensor, next time it happens i will disconnect the maf sensor and see what happens.
any ideas,
thanks.
p.s.
i bought a mityvac model 6835 and love this tool, hook it up to your shop air and you can bleed anything, i use to clean out my power steering pump to prime and bleed my radiator, works like charm and of course to bleed my brakes, saves me big money by doing the job myself very usefull.
any ideas,
thanks.
p.s.
Jan 27, 2009 at 3:59 AM
