2002 Audi A4 About the timing belt etc.
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
BEN_25
I have an audi 2002 a4. I replaced my timing belt using the camshaft locker(were it puts the cams in in there actual position). While i was doing that i also replaced my spark plugs. When i started the car it showed these symptoms; Rough running, loss of engine power, and kind of hard to start but not realy. I checked the car and its showing me P0340 (camshaft disposition malfunction). Could it be a disposition of the belt or something dealing with sensors or the electricity?
Nov 16, 2008 at 8:14 AM
  • 31,937 POSTS
Hi there,
I would be carefully re checking the valve timing, you may be 1 tooth out, which engine do you have, i will see if i can post some pics of the set up for you.
mark (mhpautos)
Nov 16, 2008 at 8:20 AM
