i fill up my car with a diesel oil and later it goes to the exhaust and it start smoking white smoke. The pistion have been checked their fine.
Oct 21, 2008 at 1:31 AM
SAFEDRIVER213
MEMBER
You used diesel gas on a car thats suppose to use unleaded? on my, its going to be expensive. you need to flush the car, and dont drive it! it will just get worse.
Oct 23, 2008 at 12:00 PM
KENNYM
MEMBER
My car is a diesel 1.9tdi
Oct 23, 2008 at 6:30 PM
KHLOW2008
✓Experienced Mechanic
Hi kennym,
Check the oil level, did you overfill?
Sometimes when filling the oil too fast, it would get to the intake manifold if the PCV is bad.
Let it run for a while and see if the smoke clears off.
