2001 Audi A4 signal lights
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
BMWILLIAMS
My signal lights are no longer working properly. They do work but it's sparatic. I've checked the fuse but it's not that's not the problem either. What is another/are other source(s) that can cause this? Thank you for your assistance.
Brent Williams
Aug 4, 2009 at 6:32 PM
  • 75,988 POSTS
Check the turn signal flasher if not it could be the turn signal switch itself
Aug 4, 2009 at 9:34 PM
