Hi.
Thank you for your respond, This morning the oil warning light come on and the engine make noise but it happen only when I change from neutral to first and second gear at low RPM (under 2000RPM), about a second, at high RPM the noise disappear and seem like engine lost little power. I take to the shop they say will change the air valse or (sensor ) will it take care the problem? I am not sure, can you help me please. Thank you again.
Feb 2, 2010 at 3:29 AM
