2001 Audi A4 Oil Pump Issues
134,000 MILES • 4 CYL • AWD • AUTOMATIC
KPRINCE449
Had a oil presure lamp come on. Before I got it stopped it made a squlling noise and lost power. I thought the engine was blown. I pulled the valve cover and discovered that there was parts of something plastic in the timing chain at the back of the cams. I pulled the plastic pieces out and tried to start the car. No fire at all. Any ideas of what might have happened,
Aug 5, 2009 at 11:48 AM
DUBTECH
  • 159 POSTS
Any number of horrible things could have happened to that engine.
You may have had a tensioner failure due to the lack of oil pressure, which might explain the plastic pieces. But there is most likely bearing, turbo, and valve damage.
Aug 9, 2009 at 10:08 AM
