2001 Audi A4 noise when turn heater on
10,084 MILES • 6 CYL • AWD • MANUAL
TAHOEGIRL
When I turn my heater on it sounds like a belt is squeeking. I was under the impression my heater was run by a fan. Please advise.
Also I am not sure if the motor is 4 or 6 cyl. It is an Audi A4 1.8 Turbo 2001
Nov 18, 2008 at 1:42 PM
  • 31,937 POSTS
Hi there,
This noise is often a dry bearing in the fan motor, they are often a bronze type bush bearing and can be re oiled, but getting it out will be the problem, your local work shop will advise on the cost of doing this. I will have a look at the data base and let you know if there is a rough pricing to do this.
mark (mhpautos)
Nov 18, 2008 at 1:48 PM
