2000 Audi A4 speedometer and gas gauge not working
13,550 MILES • 4 CYL • 4WD • AUTOMATIC
EDWARD007
the speedometer and gas gauge both went out on the same time. the speedometer goes form 0mph to the current speed, sometimes it gets suck at zero, and when i put on the breaks it goes up to the speed that im currently going.the same thing happends with the gas gauge. the check engine light does not trun on. what can cause this?
Jul 11, 2010 at 12:43 PM
SHELLIFSG
It sounds like your speedometer cable is loose or speedometer may not be grounded properly.. Had a similar problem with my car.
Jan 2, 2011 at 4:18 AM
