2000 Audi A4 Car Wont's Start
124,000 MILES • 4 CYL • FWD • MANUAL
COLTON5BUCKS
What would cause my Audi to all of sudden die while i was driving it? After it stopped running i try to turn it over and it acts like the starter is not engaging. I noticed an aluminum pipe thats about 1/2 inch to 3/4 inch in diameter that had been broken in the central passenger side almost directly under tha radiator.........There are two of these pipes/tubes that run paralell to eachother running from passenger side to the center. Could these be a type of vacuum tubing that activates the starter or keeps the motor running?
Thank You So Much
Sincerely
Colton Belliston
Oct 23, 2008 at 7:42 AM
DAVE H
  • 13,383 POSTS
i really need a little more info to answer your questions ?? does the engine make any sound when turning the key or just a clicking or no noise ? the pipes you see are nothing to do with starter motor but sound 2 me like air con pipes ??
Nov 5, 2008 at 11:38 AM
