the ac is not cooling in the car. Is there a relay for the magnetic clutch? How can I troubleshoot the problem?
Jun 29, 2008 at 10:26 AM
RJJ 1
MEMBER
there is a high pressure/low pressure switch on the condenser if the pressure is to low the compressor and the cooling fan won't turn on,so check the system for enough pressure
