2000 Audi A4 ac is not cooling
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEGAMAN
the ac is not cooling in the car. Is there a relay for the magnetic clutch? How can I troubleshoot the problem?
Jun 29, 2008 at 10:26 AM
RJJ 1
  • 16 POSTS
there is a high pressure/low pressure switch on the condenser if the pressure is to low the compressor and the cooling fan won't turn on,so check the system for enough pressure
Jul 26, 2008 at 5:45 PM
