1999 Audi A4 slugish acceleration
116,000 MILES • 4 CYL • FWD • AUTOMATIC
JWHIRRED
Today my A4 suddenly started to "chug" when accelerating, as if the compression or firing were off. When using the automatic "stick", when I would leave in in lower gear and let it wind out a bit, it wasn't too bad. But accelerating for freeway speeds seemed like a bad idea. The check engine light came on and flashed, and continued flashing. What is the likely problem and would it be worth my while to take it to a dealer to fix or have it worked on by someone else. To date, I have taken it to the deal for all service. These German cars seem very fussy and fixing them is expensive. I am trying to decide in fixing it would be worth while or if I should call it a day and get a new car.
Mar 8, 2009 at 7:52 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated Take the vehicle to a good autoparts store (autozone etc.) have them read the cars PCM for fault codes ...(most do this free) repost with the codes for a better diagnosis and repair information .. it may well be something you can repair yourself !! hope this helps .. let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_90.png
Mar 8, 2009 at 9:07 AM
