1999 Audi A4 Rear rattle
145,000 MILES • 6 CYL • AWD • AUTOMATIC
AJOHNSON640
There is a rattle that comes from the rear when I accelorate, but once I'm up to speed it goes away. I've had viscus mentioned and rear diiferential, I hear that there might be a fluid that I can add to the rear end that might help if it is just worn. Please help in anyway possible with imput. Thanks. Aaron
Jun 24, 2010 at 11:10 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would be checking the simple things first, loose or broken exhaust mounts, worn suspension bushes, have a mechanic check over the rear end for any like problem, start here.
mark (mhpautos)
Jun 27, 2010 at 2:46 AM
