1999 Audi A4 Engine light
101,000 MILES • 4 CYL • AWD • AUTOMATIC
HIEDIKAY
My engine light came on and I drove the car for about a week. Since I had the timing belt changed, I assumed it not to be anything more then a service check. However, the car started to sputter or pull when giving gas.
Jan 28, 2009 at 8:40 AM
DOCFIXIT
  • 18,828 POSTS
There is a problem computer has picked up a fault. Go to an Auto Zone or similar have codes read the post in P0xxx format. Will advise
Jan 29, 2009 at 1:12 AM
HIEDIKAY
Will an OBD2 scanner detect the codes or problem or do I need to take it and have someone at auto zone try? THX
Jan 29, 2009 at 11:18 AM
DOCFIXIT
  • 18,828 POSTS
Drive up tell them you have ligt on they will scan tell you what code. You post and I will tell you what's up.
Jan 30, 2009 at 1:21 AM
