How can I fill or change the transmission oil. There is no stick to fill or change the transmission.
Sep 1, 2008 at 2:35 PM
KHLOW2008
✓Experienced Mechanic
Hi rastae6,
You need to remove drain plug 2 to check the fluid level. # 1 is for draining the fluid.
There is a special tool to fill the fluid.
Sep 5, 2008 at 4:34 AM
