1999 Audi A4 99 Audi A4 Stumbles on acceleration
1999 AUDI A4
150,000 MILES • 4 CYL • AWD • MANUAL
ASTERPIS
99 Audi A4 Stumbles on acceleration and stalls.
Aug 13, 2008 at 8:11 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 13, 2008 at 9:09 AM
