1998 Audi A4 will not start
TOPFINN
Engine Mechanical problem
1998 Audi A4 6 cyl Front Wheel Drive Manual
starter motor ok, cam belts ok, oil alert comes on & will not start
May 7, 2009 at 8:10 AM
  • 75,988 POSTS
Could be fuel or spark problem do below
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
May 7, 2009 at 10:31 AM
