1998 Audi A4 How do you pull out a 1998 Audi A4 1.8 t engin
60,000 MILES • 4 CYL • FWD • MANUAL
BENZENWENGER
  • 38 POSTS
Hi I have a 1998 Audi A4 1.8 T and im thinking a piton blew so I want to take the Engine out and rebuild it if I can but I don't no if if comes out under the car or on top and it has a Manual Tranny wood it be easy to pull them out at the same time can you help me thanks
Sean
Mar 16, 2009 at 5:08 PM
DOCFIXIT
  • 18,828 POSTS
Before you pull engine run a compression test. May have burnt a valve.
Engine comes out top side and you can pull trany attached.
Mar 17, 2009 at 1:23 AM
BENZENWENGER
  • 38 POSTS
Its the piston you can start the car makes a rely bad noise deep in the engine far back its not on top what sucks the one other thing I wanted to no is it easer to pull the tranny with the engine or easer just to leave the tranny in and if I can rebuild the engine or put a nother one in it. thanks
Sean
Mar 17, 2009 at 6:31 AM
DOCFIXIT
  • 18,828 POSTS
For me easier to pull with manual trans an auto i'd leave in. But trying to line up clutch, input shaft and mount to bellhousing is a real pain. Bone yard engine would be cheaper over rebuild but if want to keep car few more years you'll be better off with rebuild.
Mar 17, 2009 at 6:58 AM
