1998 Audi A4 engine computer
125,000 MILES • 4 CYL • AWD • MANUAL
707DONNIEKOSTICK
can i repair the engines computer i think it has a bad driver for cylender #2
Sep 8, 2009 at 5:52 PM
  • 75,988 POSTS
Best check 1st the sparkplug, compression and injector for that cylinder if you're talking about misfiring.
Sep 8, 2009 at 6:12 PM
707DONNIEKOSTICK
[quote:2290adc5bc="rasmataz"]Best check 1st the sparkplug, compression and injector for that cylinder if you're talking about misfiring.[/quote:2290adc5bc] well i already replaced the coil packs and plugs, the only thing i havent tested is the injector, but the thing is im getting no spark when i ground the plug. i guess the only way to check for a bad computer is grounding the coil pack to check for a little spark. but a bad injector will cause a missfire?
Sep 12, 2009 at 7:32 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sep 13, 2009 at 4:23 AM
707DONNIEKOSTICK
so maybe i have a problem somewhere in the engine wiring harness
Sep 13, 2009 at 6:37 PM
