HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Audi
A4
Drivetrain
Transmission
Clutch
SPONSORED LINKS
1998 Audi A4 CLUTCH NOISES
RENAKASHELDA
MEMBER
1998 AUDI A4
6 CYL
2WD
MANUAL
140,000 MILES
Why is the cluth making funny noises when I press down on it?
Monday, December 14th, 2009 AT 7:26 PM
DOCFIXIT
MECHANIC
Most likely faulty release bearing.
SPONSORED LINKS
Wednesday, December 16th, 2009 AT 9:46 AM
RENAKASHELDA
MEMBER
Owh ill check on that. Thank you
Wednesday, December 16th, 2009 AT 11:58 AM
Please
login
or
register
to post a reply.
Related Transmission Clutch Content
When You Push The Gas, It Just Rev's Up?
I'm Having Problems Withe Transmission. I Had The Clutch Replaced About 6 Months Ago, And I Tried To Put It In 1st Gear, And The...
Asked by
allyssa.gunn
1 ANSWER
8 IMAGES
1998
AUDI A4
VIDEO
How to Check Your Clutch Operation?
Instructional repair video
GUIDE
Clutch Replacement
Before you replace your clutch its a good idea to see how the clutch works and the symptoms of a bad clutch. A clutch will have problems and can stop working all...
1998 Audi A4 1998 A4 2.8 Tiptonic Mode Stoped Working...
Hi I Have An 1998 Audi A4 2.8 V6 And When I First Bought The Car It Had 132,000 Kms On It After A Week The Transmission Started Acting Up...
Asked by
initial_JD
1 ANSWER
1998
AUDI A4
1999 Audi A4 Change Transmission Oil
How Can I Fill Or Change The Transmission Oil. There Is No Stick To Fill Or Change The Transmission.
Asked by
rastae6
1 ANSWER
1999
AUDI A4
1996 Audi A4 Transmission Fluid For A4 1.8
1996 Audi A4 4 Cyl Front Wheel Drive Automatic Can You Reccomend Atf For This Car, It's Very Hard To Find In Thailand, What Is Atf Can...
Asked by
kodomo
1996
AUDI A4
1999 Audi A4 No Drive At All, Forward Or Reverse.
Transmission Problem 1999 Audi A4 4 Cyl Four Wheel Drive Automatic 125k Miles I Just Bought A A4 With The "transmission Out" Before I...
Asked by
planebones
1999
AUDI A4
VIEW MORE
SPONSORED LINKS
Clutch and Throwout Bearing Front Wheel Drive
Clutch/Flywheel/Rear Main Seal Replacement
Online car repair manuals
