1998 Audi A4 AUDI SHUDDER
170,000 MILES • 6 CYL • AWD • AUTOMATIC
DRCIENCIA
MY AUDI SHUDDER WHEN I DRIVE 360 DEGREE AND WHEN I GOING ABOUT 35 MILE ALSO SHUDDER
Mar 8, 2010 at 1:27 PM
AUTOMD
  • 50 POSTS
When you changed the tranny fluid, did you do a complete change or just drop the pan? It almost always rears its head right after it shifts into OD and you are going easy on the throttle.
Mar 11, 2010 at 1:10 PM
DRCIENCIA
I REPLACE THE DRIVE SHAFT FIRS THINKING THIS CUD BE THE PROBLEM BECAUSE HAVE A OIL LIKE FROM TRANSMISSION SEAL I REPLACE THE TRANSMISSION SEAL AND THE CENTER DIFFERENTIAL FLUID AND ALSO DRAPE THE OIL PAN OF THE TRANS,REPLACE THE OIL, TODAY I REMOVE Torsen Center Differential,I TAKE LOOK AND I FOUND GOLD POWDER
ON THE OIL I DO NOT FOUND NO HARDWARE BROKEN ONLY THE GEAR WAS SHAINE
Mar 12, 2010 at 1:17 PM
