1997 Audi A4 wiper fluid
150,000 MILES • 6 CYL • AWD • AUTOMATIC
DAMOSHAMO1
Over the past month my wiper fluid stop squirting out,gradually. Now nothing comes out, checked the fuse and filled the basin up. is there a motor that sends it to the hood or what?thanks
May 7, 2008 at 11:56 AM
  • 31,937 POSTS
Hi there.
yes there is a small pump normally fitted to the reservoir. If you can hear it working, check that the nozzles are not blocked. Often dry fluid additives can block the nozzle and this can be cleared with a fine pin.
mark (mhpautos)
May 7, 2008 at 2:53 PM
