i just changed the water pump on my car and its still heating up .....is their a way to take the air out of the car ...
Jul 31, 2009 at 7:56 AM
BLUELIGHTNIN6
✓Experienced Mechanic
remove radiator cap and run engine at operating temp to bleed cooling system
Jul 31, 2009 at 8:12 AM
FLORES213
MEMBER
is their anything else i can do then just taking the cap out
is their any way i can leed out air out of the cooling sytem i was tol that this types of cars have something like that
Jul 31, 2009 at 8:20 AM
BLUELIGHTNIN6
your vehicle may be equipped with a bleeder valve for the cooling system. if so, it will be located near the radiator cap , open the valve to release any trapped air in the system.
are you certain the water pump was the cause of your overheating issue?
Jul 31, 2009 at 8:22 AM
FLORES213
MEMBER
also my car has two fans but only the big one works right away as soon as you turn on the car ..i dont know why the other doesnt work
also were do i check the transmisson oil for this car where is it located
