The Audi continues to overheat especially when driving it will overheat 2-5 minutes. If i let it idle it will idle for hours with temp gage in middle. when giving it gas or driving it overheats. So far I have replaced thermostat, and bled coolant lines near heater core as instructed.fan clutch was bad but now is fixed and working properly. The radiater does not seem to be clogged hot air is coming from fan when engine is hot. No water in oil, No white smoke in tailpipe .Engine runs smooth. Could it be the waterpump? or what else should I look for? I did not see it leaking but it has 197000 miles. How do I check to see if the waterpump is not functioning adequately
Mar 19, 2009 at 11:56 AM
