Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Audi
A4
Suspension
Lower Control Arm
Replace/Remove
1997 Audi A4 control arms
1997 AUDI A4
205,000 MILES • 6 CYL • AWD • MANUAL
JACKFIRE57
MEMBER
How hard is it to replace myself and how to do it ?
Aug 28, 2008 at 9:38 AM
KHLOW2008
Experienced Mechanic
Hi jackfire57, Depends on your mechanical abilities regarding the term hard. You need to remove ball joints so a remover is necessary.
Aug 29, 2008 at 1:30 AM
JACKFIRE57
MEMBER
Would like detailed instructions on the replacement of A4 Control Arms .
Aug 29, 2008 at 2:04 AM
KHLOW2008
Remove any bolt that are holding the arms and the ball joints and you can get them out.
Replace 1 arm at a time.
Aug 29, 2008 at 2:32 AM
JACKFIRE57
MEMBER
Thank u ,it sounds like something i can handle .
Aug 29, 2008 at 2:37 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
