The car idles great, but soon as you hit the gas, there's no power. If you slowly hit the gas, the engine revs nicely. Thought is could be the MAF sensor, so I took it out and cleaned it. It fixed alittle of the issue, but still having the same problem. I thought it also might be the throttle, so hooked up scan tool and readjusted the throttle and still no go. There are no codes at the moment. What do you think it could be?
Jul 27, 2010 at 5:24 AM
