1996 Audi A4 Recharge ac
1996 AUDI A4
123,530 MILES • 6 CYL • 2WD • MANUAL
LUISHURTADO001
Find ac connector
Jun 14, 2008 at 10:34 PM
MANYMOTO
What I did was to get a low presure pipe with the valve in the junker, cut the valve leaving 1-1/2" of pipe in both sides of the valve, then I open the pipe in half, make a hole in the low pressure pipe and clamp the low valve with hose clamps, I use a rubber hose as a seal. recharge system and done. Works perfect.
Oct 6, 2010 at 9:00 AM
