Hi there,
Thank you for the donation,
As there are a number of components that can cause loss of ignition we first must run a diagnostic test to try and determine the exact cause as just bolting on new parts can be costly waste of time, so the first thing that should be done is to have a diagnostic scan done as this will identify any unresolved fault codes that can indicate a failed engine management component, i would be looking for a fault with the crank angle sensor or the cam angle sensor as these can both be the reference signal for the ignition system, next i would be testing the coil, i can give you the test procedure for the crank , cam sensors and the coil, but you will need some test equipment and an understanding of automotive electrics, if in any doubt your service center can assist you here.
Let me know which way you wish to proceed, but the important thing is get a scan done first.
Mark (mhpautos)
Nov 6, 2009 at 10:36 AM
