hi, i need advice on my audi, the engine oil is mixing with the water.. the block was skimmed and the heads. the engine started mixing the oil and water and i then took the block and heads to the engineering for pressure testing. all came back that it was fine. i redonr the engine and i am still having the same problem, the vehicle doesnt have an oil cooler as i had that checked already. if any body can give me advise thanks
Sep 11, 2010 at 12:16 PM
