Hi, I am replacing the crank angle sensor or RPM sensor as Audi calls it. I have the sensor out and have threaded the wire up under the inlet manifold but from here I cannot see where it goes so that I can unplug it to take it fully out. Can you please let me know where the plug is located. I have wriggled the wire back and forward and just cant see where it disappears to and where it terminates. I had a good look online and cant find the info anywhere. I appreciate your help many thanks in advance. Cheers.
Jun 8, 2018 at 6:12 PM
