1990 Audi 80 No Spark After Distributor
SWATCH_KIMO
hi i have audi 80 1990.i had prob 1st when i turn car off it make back fire.and i toke Distributor out 2 make new timing.then i moved Crank to cam bilt sign (OT)and installed Distributor.but motor wont turn on.i checked the wire come from Iginition coil i found no fir come.i got other iginition but still not going.
i dont know what wrong it was working very good.please i need help.ask me if you need pic.
thanks
Jun 19, 2007 at 5:35 PM
DR LOOT
  • 2,311 POSTS
okay listen up, you're going to have to take out spark plug number one, turn the vehicle over until you feel compression coming out of the cylinder, then put it on top dead Center, but you're distributor cap on, to check which way it needs to point to cylinder number one then try and see if it starts, another problem I think you may be having is that you cannot position the distributor good enough to make its mark, so listen up again it's called static timing, do not tighten up the distributor all the way, put your cap on, take the spark plug that you have removed from cylinder number one, hold it to ground, twist the distributor until it sparks, you'll have to do it several times until you can stop the distributor right when it sparks, tightened up the distributor but the spark plug back in and it should start up, then you will have to time it
Aug 26, 2009 at 10:54 AM
Suggested Repair
Set static timing: remove spark plug 1, crank until compression is felt, then set top dead center. Fit the cap and confirm the rotor points to cylinder 1. Leave the distributor loose, ground the removed plug, and rotate the distributor until it sparks. Lock it at that point, reinstall the plug, start the engine, and finish with a timing adjustment.
Conversation Summary
A 1990 Audi 80 backfired when shut off. After the distributor was removed and reinstalled at the OT mark, the engine would not start and no spark came from the ignition coil, even with another coil. The expert advised static timing on cylinder 1: find compression and top dead center, point the rotor correctly, rotate the loose distributor until the grounded plug sparks, then tighten it and time the engine.
