Antenna, 1986 Audi 4000, motor pushes antenna out
1986 AUDI A2
CLYDE70
Antenna works but motor will not stop—it pushes the mast all the way out.
I believe this is a matter of the stop switch inside the antenna mechanism. This switch tells the motor to stop when the antenna is extended.
Rather than "re-invent the wheel," perhaps someone can tell lme how to set the stop switch correctly so that the antenna stops when it should.
Mileage on car—190,000
engine size—1.8 l gas
Nov 2, 2007 at 5:18 AM
DR LOOT
  • 2,311 POSTS
it is most likely a micro switch the same thing happen on my Mercedes, but I just went to the junkyard and got me another antenna for 25 bucks and now it works normal
Aug 26, 2009 at 8:57 AM
