where is the computer diagnostic port?
1999 AUDI 90
AUDIMATT
Thank you for your time. We checked under the hood and also by where the left foot would be and are unable to find it.
Dec 11, 2009 at 7:49 AM
SQM
  • 6,383 POSTS
I am assuming you meant to put a 1989 Audi 90. They did not make the 1990 in the 1999.
The diagnostics port can be either of two locations, depending on the manufacturers date for this vehicle.
I can be under the hood, in the fuse box that is close to the firewall.
Or it can be under the dash next to where the steering shaft goes into the firewall.
Look for 3 connectors next to each other.
Here is a chart to VW OBD1 codes, they are the same as Audi codes.
https://www.2carpros.com/articles/volkswagen-code-retrieval-procedure-and-code-definitions-1988-1995-odb1
Sep 22, 2021 at 12:50 PM
