1995 Audi 90 Power windows and Sunroof wont work
179,000 MILES • 6 CYL • AWD • MANUAL
SEAMUSMULLIGAN
My power windows and power sunroof won't work. I ran power to the window motors and they all work, however, the switches wont activate the motor. Since there is about 20 wires going to the drivers door, I do not know which wires are the hot wires. I searched, but cannot find a fuse that is blow, nor can I find a fuse labeled windows. Where is the fuse located or any suggestions?
Jul 13, 2010 at 2:18 PM
KHLOW2008
  • 41,812 POSTS
Hi SeamusMulligan,
Thank you for the donation.
The main power source is from fuse # 43 ( 20 A) located in Auxiliary Relay Panel, behind left side of instrument panel.
It is the Red/Black wire to the Power Control Module ( terminal 2) at same location.
The power to the power window switch is from terminal # 8 of Power Window Control module to the door switches ( Red/Blue wire).
Jul 14, 2010 at 3:22 AM
JGSELLAR
If the power windows, sunroof, heating fan, wipers and washers do not work, the problem is likely with the Relief Relay in the fuse box under the hood. The relay is numbered 213 and is easily removed. Make sure the terminals are clean, give it a few light taps and reinstall.
Mar 26, 2015 at 3:08 AM
