1995 Audi 90 Clutch Replacement
182,000 MILES • 6 CYL • AWD • MANUAL
BECKYP1712
My Audi will not go into gear and now it smells like something is burning. A mechanic told me it was a clutch problem but wouldn't work on it. I have to take it somewhere else how much should it cost.?
Aug 19, 2010 at 2:33 AM
KHLOW2008
  • 41,812 POSTS
Hi beckyp1712,
Thank you for the donation.
Symptoms do indicate a fault/worn clutch and most non Audi trained people would be reluctant to do the job as it is not easy to perform.
The book time for clutch replacement is 7 hours with additional time to be added if the flywheel and/or oil seals etc to be removed/replaced.
A rebuilt clutch pressure plate is listed at $195.00.
Clutch bearing = $ 71.00.
Clutch dis price is not available in our database.
Prices for parts and labor varies according to region so you would have to check out local conditions to be accurate.
Aug 19, 2010 at 6:56 AM
