Engine Mechanical problem
1988 Audi 90 All Wheel Drive Manual
I have a 1988 Audi 90 Quattro. When the car sits for an hour or so, it runs perfect. About 3-5 miles after driving it, I will come to a stop and it will stall. Almost as if it is losing power. After it stalls, it takes a couple minutes to start it back up. Once it is started it chugs in every gear while going down the road, and tries to die out. At this point I must have the gas pedal to the floor to keep the engine running. I have replaced the fuel distributor, and the fuel pressure regulator. Both OEM. The fuel pump has pressure and runs fine. Maybe the fuel pump is shutting off. When The fuel gets below a quarter tank it chugs worse and dies out as soon as I come to a stop and try to accelerate. I checked the fuel pump and It was giving out good pressure, I also checked the fuel filter, Its good but i will replace it.
There was a security feature added sometime in its life to prevent theft, It was wired to the cold start valve, and after every time you restart it you must push that button. Would that contribute to the problem?
Jul 18, 2010 at 11:15 AM
