1986 Audi 5000 wont start
SUMMERWYNNE
Engine Mechanical problem
1986 Audi 5000 All Wheel Drive Manual 171500 miles
my 2.2 5cylinder turbo is not wanting to re start after it has been driven & wormed up. It will restart after 1hr or 2.
Oct 2, 2009 at 3:59 PM
2 CARVINCE
  • 31 POSTS
you need a pair of fuel gauges and test fuel pressure at the fuel distributor . there is a fuel regulator that is located on the side if the block that the fuel lines run to and out of , it could be your problem also ?if you could get a fuel reading message me back and i will go over it with you
Jan 20, 2010 at 1:03 PM
