1990 Audi 200 Clutch not working
1SEMINOLE
Transmission problem
1990 Audi 200 4 cyl Four Wheel Drive Manual 5 cyl miles
I have an AUDI 200 Quattro 5 cyl. 5 spd.
While pressing the clutch, it would go down almost to the floor but still able to press it and shift. It seemed like if I had a very short clutch... this happened twice and after a day or two the clutch went back to "normal" it's original position. Then while driving, I pressed on it and it went all the way to the floor not coming back at all. I can't shift at all. When the car is parked and completely off, I can shift all the gears smoothly, there's no grinding. I'm wondering if it's only the clutch slave cylinder that is at fault. Any suggestions? Can you guide me?[img:137bbd1185]http://www.2carpros.com/forum/automotive_pictures/220630_893721261A_slave_cylinder_1.jpg[/img:137bbd1185]
Jul 29, 2008 at 7:24 PM
  • 55,676 POSTS
Hi if the clutch slave is not leaking the clutch master has gone bad and needs replacing.
Nov 12, 2008 at 11:21 AM
