1994 Audi 100 WHY TO THE COOLANT OIL?
192,888 MILES • 6 CYL • 2WD • AUTOMATIC
YABU1982
THE RADIATOR COOLANT ALWAYS NILL? EVERY DAY I FILL OUT THE RADIATOR WHAT IS THAT PROPELEM HOW TO FIX AND THE SECOND QUESTION MY CAR TURN SIGENAL NOT BLINK?PLEASE SEND QUICLY
Oct 20, 2010 at 1:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
For the turn signal problem, check the turn signal fuse and turn signal/hazard flasher relay.
For the coolant loss, you will need to check the engine compartment for wet spots. Also see if the exhaust is putting out white smoke. There are many things that can cause coolant loss such as leaky radiator hoses, cracked radiator, faulty cylinder head gasket etc...
Oct 20, 2010 at 6:29 PM
